Sound Show Pro - Mobile
Improve your Sound Show Experience
Unlock the complete version of Sound Show on Android for only 25€
One-time payment!
It comes with many additionnal features and customization options
Discover how it can help you achieve your goals more effectively!
Buy Sound Show Pro
No Limits on Categories and Sounds
Add as many sounds and categories as you want. Navigate through them easily with a paging system.
Grids Size Customization
Fully customize your button grid. wwhether you need a large number of small buttons or fewer, larger ones, the choice is yours.
Adapt the interface to perfectly match your performance style.
Custom Icons
Use your icons to boosts the visual appeal of your projects and speed up identification of the right sound for the perfect moment.
Visual Sound Editor
Easily adjust the start and stop points of your sounds with a clear and intuitive interface
Skins
Choose between various skins, to adapt the appearance to suit your taste or environment, whether for better readability in different lighting or to reflect your personal style.
Touch and Phone Mode
You can switch to layouts specifically designed for touchscreens or smaller interfaces, to fit your use case.
Support Future Development
Contribute to the ongoing evolution of Sound Show. Your support enable sme to keep building exciting new features and improvements.
Comparison Pro/Free
Accessibility is a key point behind the creation of Sound Show
That's why the core version of Sound Show is free to use.
For those looking for a little something extra, I've launched Sound Show Pro.
This version comes with some exclusive features to elevate your sound experience.
Also it helps me continue to innovate, ensuring that Sound Show keeps getting better.
Free
€ 0. 00
  • Most Sound Show features
  • Limit to 10 tabs and 40 sounds per tab
  • Limited visual customization
  • Some specific modules locked : midi, lighting...
Pro
€ 45​ .00
  • All Sound Show features
  • No limit on sounds and tabs
  • Enhanced visual customization : Varying grid sizes, Skins, Touch mode/Phone mode, icons...
  • Additional modules : Midi controller, Lighting (QLC+), OBS, remote interface...
